相对定位/绝对定位含义
753 0
<p><br/><img src="/upload/image/20230619/1687140832173603.png" alt="5.6【极课工控】基本定位指令的讲解"/></p><p><span style="color: rgb(51, 51, 51); font-family: -apple-system, BlinkMacSystemFont, &quot;Segoe UI&quot;, Helvetica, Arial, sans-serif, &quot;Apple Color Emoji&quot;, &quot;Segoe UI Emoji&quot;; font-size: 14px; text-wrap: wrap; background-color: rgb(255, 255, 255);">理解1:</span><br/><span style="color: rgb(51, 51, 51); font-family: -apple-system, BlinkMacSystemFont, &quot;Segoe UI&quot;, Helvetica, Arial, sans-serif, &quot;Apple Color Emoji&quot;, &quot;Segoe UI Emoji&quot;; font-size: 14px; text-wrap: wrap; background-color: rgb(255, 255, 255);">1.这是一个绝对坐标系</span><br/><span style="color: rgb(51, 51, 51); font-family: -apple-system, BlinkMacSystemFont, &quot;Segoe UI&quot;, Helvetica, Arial, sans-serif, &quot;Apple Color Emoji&quot;, &quot;Segoe UI Emoji&quot;; font-size: 14px; text-wrap: wrap; background-color: rgb(255, 255, 255);">2.两辆车,一辆是“绝对”车,一辆是“相对”车</span></p><p style="overflow-wrap: break-word; margin-top: 0px; margin-bottom: 15px; padding: 0px; color: rgb(51, 51, 51); font-family: -apple-system, BlinkMacSystemFont, &quot;Segoe UI&quot;, Helvetica, Arial, sans-serif, &quot;Apple Color Emoji&quot;, &quot;Segoe UI Emoji&quot;; font-size: 14px; text-wrap: wrap; background-color: rgb(255, 255, 255);"><br/></p><p style="overflow-wrap: break-word; margin-top: 0px; margin-bottom: 15px; padding: 0px; color: rgb(51, 51, 51); font-family: -apple-system, BlinkMacSystemFont, &quot;Segoe UI&quot;, Helvetica, Arial, sans-serif, &quot;Apple Color Emoji&quot;, &quot;Segoe UI Emoji&quot;; font-size: 14px; text-wrap: wrap; background-color: rgb(255, 255, 255);">两辆车都在500绝对位置上,“绝对”车绝对定位功能定位 2000位置<br/>“相对”车使用相对定位2000位置(相对的是启动前的 自己 所在位置为0)</p><p style="overflow-wrap: break-word; margin-top: 0px; margin-bottom: 15px; padding: 0px; color: rgb(51, 51, 51); font-family: -apple-system, BlinkMacSystemFont, &quot;Segoe UI&quot;, Helvetica, Arial, sans-serif, &quot;Apple Color Emoji&quot;, &quot;Segoe UI Emoji&quot;; font-size: 14px; text-wrap: wrap; background-color: rgb(255, 255, 255);">最后会发现:<br/>“绝对”车,运动到的位置就是绝对坐标系下的2000<br/>“相对”车,运动到的位置是绝对坐标系下的2500</p><p style="overflow-wrap: break-word; margin-top: 0px; margin-bottom: 15px; padding: 0px; color: rgb(51, 51, 51); font-family: -apple-system, BlinkMacSystemFont, &quot;Segoe UI&quot;, Helvetica, Arial, sans-serif, &quot;Apple Color Emoji&quot;, &quot;Segoe UI Emoji&quot;; font-size: 14px; text-wrap: wrap; background-color: rgb(255, 255, 255);">理解2:<br/>我们开车,两辆车都在高速上跑,速度一样,距离保持一致,则这两个车是相对静止的。</p><p style="overflow-wrap: break-word; margin-top: 0px; margin-bottom: 15px; padding: 0px; color: rgb(51, 51, 51); font-family: -apple-system, BlinkMacSystemFont, &quot;Segoe UI&quot;, Helvetica, Arial, sans-serif, &quot;Apple Color Emoji&quot;, &quot;Segoe UI Emoji&quot;; font-size: 14px; text-wrap: wrap; background-color: rgb(255, 255, 255);">没有任何方法可以证实一个物体是在绝对静止之中。绝对静止的物体是不存在的。静止只是一个物体对于它周围的另一个参照物保持位置不变,所以也只能是相对运动和相对静止,运动和静止是相对的。</p><p><br/></p>
